Add a new static source group to create an entry that the switch cannot prune from the distribution tree.
Before you can configure a static source group, you must globally enable one of the following protocols:
PIM-SM
PIM-SSM
An attempt to add a duplicate of an existing source-group entry results in an error message.
This procedure is supported only on a DvR Controller. It is not supported on a DvR Leaf node.
The switch supports PIM only in the Global Router. You cannot configure static source groups for specific VRF contexts.
